Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device with an M-type barrel requiring up to 9 volts and 2 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
For frequent travelers, this power adapter saves you from buying multiple adapters. To ensure it will work in your region and the region you're traveling to, the power adapter features 100-240V automatic switching and regional clips for North America, Europe, United Kingdom and Australia.
Replace your failed or lost power adapter
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics. -
Keep a spare power adapter on hand
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source. -
The ideal travel power adapter
For frequent travelers, this power adapter saves you from buying multiple adapters. To ensure it will work in your region and the region you're traveling to, the power adapter features 100-240 V automatic switching and regional clips for North America, Europe, United Kingdom and Australia.
- StarTech.com Universal Replacement Power Adapter - DC 9 Volts, 2 Amps Power Adapter (SVA9M2NEUA) - power adapter
- Power adapter - external
- 160 g
- Localisation
- Australia, North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- DC 9 V
- Included Accessories
- Power adapter
- 4.6 cm x 8.2 cm x 3.6 cm
- 2-year warranty
- Designed For
- P/N: CPNT2VGAA, MCMGBSC055, RS232EXTC1, RS232EXTC1EU, RS232EXTC1GB, ST121REU, ST121RGB, ST121UTPEU, ST122UTPAGB, ST122W, ST124L, ST124W, ST128L, SV1631DUSB, SV1631DUSBGB, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV431DVIDDU, SV565DUTPU, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV831DUSB, SV831DUSBGB
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- DC 9 V
- Max Electric Current
- 2 A
- Power adapter
- Cables Included
- Power cable - integrated
- 4 switchable sockets
- UL, FCC, RoHS, WEEE
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80%
- 4.6 cm
- 8.2 cm
- 3.6 cm
- 160 g
- Designed For
- P/N: CPNT2VGAA, MCMGBSC055, RS232EXTC1, RS232EXTC1EU, RS232EXTC1GB, ST121REU, ST121RGB, ST121UTPEU, ST121UTPGB, ST122UTPAGB, ST122W, ST124L, ST124W, ST128L, SV1631DUSB, SV1631DUSBGB, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV431DVIDDU, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV831DUSB, SV831DUSBGB
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £16.93 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £10.94 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.73 |
