StarTech.com DC Power Adapter - 9V, 2A
Quicklinx: BN4GWS00 Mfr#: SVA9M2NEUA
£11.91 ex VAT
£14.29 inc VAT
Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device with an M-type barrel requiring up to 9 volts and 2 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
For frequent travelers, this power adapter saves you from buying multiple adapters. To ensure it will work in your region and the region you're traveling to, the power adapter features 100-240V automatic switching and regional clips for North America, Europe, United Kingdom and Australia.
  • Replace your failed or lost power adapter
  • Keep a spare power adapter on hand
  • The ideal travel power adapter
    For frequent travelers, this power adapter saves you from buying multiple adapters. To ensure it will work in your region and the region you're traveling to, the power adapter features 100-240 V automatic switching and regional clips for North America, Europe, United Kingdom and Australia.
StarTech.com Universal Replacement Power Adapter - DC 9 Volts, 2 Amps Power Adapter (SVA9M2NEUA) - power adapter
Power adapter - external
160 g
Australia, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
DC 9 V
Power adapter
4.6 cm x 8.2 cm x 3.6 cm
P/N: CPNT2VGAA, MCMGBSC055, RS232EXTC1, RS232EXTC1EU, RS232EXTC1GB, ST121REU, ST121RGB, ST121UTPEU, ST122UTPAGB, ST122W, ST124L, ST124W, ST128L, SV1631DUSB, SV1631DUSBGB, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV431DVIDDU, SV565DUTPU, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV831DUSB, SV831DUSBGB
Input Voltage
AC 100-240 V
Output Voltage
DC 9 V
Max Electric Current
2 A
Power adapter
Power cable - integrated
4 switchable sockets
UL, FCC, RoHS, WEEE
10 - 80%
4.6 cm
8.2 cm
3.6 cm
160 g
P/N: CPNT2VGAA, MCMGBSC055, RS232EXTC1, RS232EXTC1EU, RS232EXTC1GB, ST121REU, ST121RGB, ST121UTPEU, ST121UTPGB, ST122UTPAGB, ST122W, ST124L, ST124W, ST128L, SV1631DUSB, SV1631DUSBGB, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV431DVIDDU, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV831DUSB, SV831DUSBGB
BN4G StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.66
BN4G StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £514.22
BN4G StarTech.com DC Power Adapter - 9V, 2A In Stock £11.91
BN4G StarTech.com DC Power Adapter - 5V, 3A In Stock £11.96
BN4G StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.15
