StarTech.com DC Power Adapter - 5V, 4A
Quicklinx: CWSLWS00 Mfr#: SVA5M4NEUA
Hurry, only 3 left in stock!
£12.14 ex VAT
£14.56 inc VAT
Replace your lost or failed power adapter. This 5V power supply can provide a power source for any electronic device that has a C-type barrel and requires 5volts and up to 4 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
  • Replace your failed or lost power adapter
  • Keep a spare power adapter on hand
    When downtime isn't an option, keeping spare power adapters on hand ensures, that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
StarTech.com Replacement 5V DC Power Adapter - 5 Volts, 4 Amps - Power adapter - AC 100-240 V - SVA5M4NEUA - power adapter
Power adapter - external
158 g
Australia, Japan, United Kingdom, Europe, North Asia
Input Voltage
AC 100-240 V
Output Voltage
5 V
3 power tips
4.5 cm x 8 cm x 3.9 cm
P/N: PM1115UW, PM1115UWEU, ST4300U3C1, ST4300U3C1B, SV565UTPDUV, SV565UTPHDU, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB3SDOCKD, USB3SDOCKHD, USB3SMDOCK4K
Input Voltage
AC 100-240 V
Output Voltage
5 V
Max Electric Current
4 A
3 power tips
Power cable - integrated - 1.49 m
UL, FCC, RoHS
4.5 cm
8 cm
3.9 cm
158 g
CWSL StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £66.58
