Replace your lost or failed power adapter. This 5V power supply can provide a power source for any electronic device that has an N-type barrel and requires 5volts and up to 3amps of power.
The DC power supply is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
Replace your failed or lost power adapter
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics. -
Keep a spare power adapter on hand
- StarTech DC Adapter - 3A / 5V Power Adapter - Replacement Power Adapter - DC Power Supply - Universal Power Adapter - AC Adapter (SVA5N3NEUA) - power adapter
- Power adapter - external
- 204 g
- Localisation
- Australia, Japan, North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- DC 5 V
- Included Accessories
- 4 power plug adapters
- 3.2 cm x 7.6 cm x 5.5 cm
- 2-year warranty
- Designed For
- P/N: 110VDSLEX2EU, 110VDSLEX2GB, 110VDSLEXT2, DSRXL, MCM1110MMLC, MST14DP123DP, MSTDP123DP, MSTDP123HD, MSTDP124DP, MSTMDP123DP, MSTMDP123HD, MSTMDP124DP, SP123DP, ST122HD4KU, ST122PROEU, ST122VGA, ST124PROEU, sv211kdvieu, SV231USBLC, SVUSBPOWEREU, USB2001EXTV, USB2004EXTV, VS221HD2VGA, VS221VGA2HD
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- DC 5 V
- Max Electric Current
- 3 A
- UL, FCC, RoHS
- Limited warranty - 2 years
- 3.2 cm
- 7.6 cm
- 5.5 cm
- 204 g
- Designed For
- P/N: 110VDSLEX2EU, 110VDSLEX2GB, 110VDSLEXT2, DSRXL, MCM1110MMLC, MST14DP123DP, MSTDP123DP, MSTDP123HD, MSTDP124DP, MSTMDP123DP, MSTMDP123HD, MSTMDP124DP, SP123DP, ST121UTP232, ST122HD4KU, ST122PRO, ST122PROEU, ST122PROGB, ST122VGA, ST124PRO, ST124PROEU, SV211KDVI, sv211kdvieu, SV211KDVIGB, SV231USB, SV231USBGB, SV231USBLC, SV431DVIUA, SV431DVIUAGB, SV431DVIUAHR, SVUSBPOWER, SVUSBPOWEREU, USB2001EXTV, USB2004EXTV, VS221HD2VGA, VS221VGA2HD
StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £37.96 |
StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £34.58 |
StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) | In Stock | £150.50 |
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £67.70 |
StarTech.com 1 Port USB 2.0 Extender Kit | In Stock | £130.30 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £41.80 |
