StarTech.com DC Power Adapter - 5V, 3A
Quicklinx: BNNZWS00 Mfr#: SVA5M3NEUA
Type: KVM switch
Connectivity: [N/A]
Ports: 4
10 In Stock
£11.96 ex VAT
£14.35 inc VAT
Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device with an M-type barrel requiring up to 5 volts and 3 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
For frequent travelers, this power adapter saves you from buying multiple adapters. To ensure it will work in your region and the region you're traveling to, the power adapter features 100-240V automatic switching and regional clips for North America, Europe, United Kingdom and Australia.
  • Replace your failed or lost power adapter
  • Keep a spare power adapter on hand
  • Ideal travel power adapter
StarTech.com Universal Replacement Power Adapter - DC 5 Volts, 3 Amps Power Adapter (SVA5M3NEUA) - power adapter
Power adapter - external
160 g
Australia, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
DC 5 V
4 power tips
4.6 cm x 8.9 cm x 3.6 cm
P/N: BT2A, HD2SDI, HD2VID2, IC232485S, SDI2HD, SPDIF2AA, ST121HD20FXA, ST121HD20L, ST121WHDLR, ST3300U3S, STHDBTRX, SV231DVIUDDM, SV231USBDDM, SV431DVIUDDM, SV431USBDDM, USB2G4LEXT2, USB2G4LEXT2NA, VGA2HDPRO2, VID2HDCON, VID2HDCON2, VID2VGATV3, VS221HD20, VS421HD20, VS421HD4K, WIFI2HD2, WIFI2HDMC
Input Voltage
AC 100-240 V
Output Voltage
DC 5 V
Max Electric Current
3 A
4 power tips
Power cable - integrated
UL, FCC, WEEE
10 - 80%
4.6 cm
8.9 cm
3.6 cm
160 g
P/N: BT2A, CPNTA2HDMI, DS128, DVI2HDMIA, HD2SDI, HD2VID2, HDMI2DP, IC232485S, ICUSB2328, SDI2HD, SPDIF2AA, SPDIFCOAXTOS, ST121HD20FXA, ST121HD20L, ST121WHDLR, ST122LE, ST122LEU, ST123HDA, ST3300U3S, ST4300USB3, ST4300USB3EU, ST4300USB3GB, STHDBTRX, SV231DVIUDDM, SV231USBDDM, SV431DVIUDDM, SV431USBDDM, USB2G4LEXT2, USB2G4LEXT2NA, USBVGADOCK2, VGA2HDPRO2, VID2HDCON, VID2HDCON2, VID2VGATV, VID2VGATV2, VID2VGATV3, VS221HD20, VS410HDMIE, VS410RVGAA, VS421HD20, VS421HD4K, WIFI2HD2, WIFI2HDMC
BNNZ StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £69.12
BNNZ StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.66
BNNZ StarTech.com Composite and S-Video to VGA Video Scan Converter In Stock £122.16
BNNZ StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £32.14
BNNZ StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £48.75
BNNZ StarTech.com DC Power Adapter - 9V, 2A In Stock £12.33
BNNZ StarTech.com DC Power Adapter - 5V, 3A In Stock £11.96
BNNZ StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.15
Type: KVM switch
Connectivity: [N/A]
Ports: 4
