StarTech.com DC Power Adapter - 24V/6.6A
Quicklinx: HKKHWS00 Mfr#: 160W-POWER-ADAPTER
12 In Stock
£64.68 ex VAT
£77.61 inc VAT
Power a StarTech.com Industrial USB Hub, or other device with a 2-or-3-wire terminal block DC input, using this 24V Universal Power Adapter.
  • High-Performance Universal Power Adapter
    The Power Adapter features an auto-switching 100-240V AC input with a 24V/6.6A (158.4W) DC output and attached 4ft (1.2m) DC cord. Four 4ft (1.2m) regional power cables are included, to ensure international support: • North America - Type-A NEMA 1-15 • United Kingdom - Type-G BS 1363 • Europe - CEE 7/7 • Australia/New Zealand - Type-I AS 3112
  • Device Compatibility
    The Power Adapter features two bare-wire leads with both 2-conductor and 3-conductor terminal block connectors included, for seamless integration with a variety of devices. This power supply can be used as an accessory and primary power source for many StarTech.com Industrial USB Hubs, such as: • 16-Port Industrial USB 5Gbps Hub (5G16AINDS-USB-A-HUB) • 10-Port Industrial USB 5Gbps Hub (ST1030USBM) • 7-Port Industrial USB 5Gbps Hub (ST7300USBME) • 7-Port Industrial USB 2.0 (480Mbps) Hub (HB20A7AME) • 7-Port Industrial USB 2.0 (480Mbps) Hub with Extended Temperature Range (ST7200USBM) • 4-Port Industrial USB 2.0 (480Mbps) Hub with Extended Temperature Range (HB20A4AME) • 4-Port Industrial USB 2.0 (480Mbps) Hub (ST4200USBM) This power adapter can also be used to replace a lost or broken power adapter, or can be kept as a redundant back-up power brick for mission critical applications for StarTech.com Industrial USB Hubs that include a power adapter, such as: • 10-Port USB 5Gbps Industrial Hub (HB30A10AME) • 7-Port USB 5Gbps Industrial Hub (HB30A7AME) • 4-Port Industrial USB 5Gbps Hub (ST4300USBM)
StarTech.com 160W Universal DC Power Adapter (24V/6.6A), 2-Wire Cord and 2/3-Pin Terminal Blocks, 100-240V AC/DC External Power Supply for Industrial USB Hubs, NA/UK/EU/ANZ Cords - 4ft/1.2m DC Power Cord (160W-POWER-ADAPTER) - power adapter - 158.4 Watt
Power adapter - external
291 g
Australia, New Zealand, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
DC 24 V
Power Capacity
158.4 Watt
4 power cords, two conductor terminal block connector (attached), three conductor terminal block connector
5.3 cm x 11.5 cm x 3.7 cm
Input Voltage
AC 100-240 V
Output Voltage
DC 24 V
Max Electric Current
6.6 A
Power Capacity
158.4 Watt
DC power cable - integrated - 1.2 m
Plastic housing
UL, FCC, RoHS, PSE Mark, REACH
5 °C
55 °C
20 - 80%
5.3 cm
11.5 cm
3.7 cm
291 g
Shipping Width
16 cm
Shipping Depth
9 cm
Shipping Height
20 cm
Shipping Weight
350 g
HKKH StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £98.93
HKKH StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.14
HKKH StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £133.39
HKKH StarTech.com 7-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply In Stock £125.24
HKKH StarTech.com 10-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply In Stock £166.04
