Power a StarTech.com Industrial USB Hub, or other device with a 2-or-3-wire terminal block DC input, using this 24V Universal Power Adapter.
High-Performance Universal Power Adapter
The Power Adapter features an auto-switching 100-240V AC input with a 24V/6.6A (158.4W) DC output and attached 4ft (1.2m) DC cord. Four 4ft (1.2m) regional power cables are included, to ensure international support: • North America - Type-A NEMA 1-15 • United Kingdom - Type-G BS 1363 • Europe - CEE 7/7 • Australia/New Zealand - Type-I AS 3112 -
Device Compatibility
The Power Adapter features two bare-wire leads with both 2-conductor and 3-conductor terminal block connectors included, for seamless integration with a variety of devices. This power supply can be used as an accessory and primary power source for many StarTech.com Industrial USB Hubs, such as: • 16-Port Industrial USB 5Gbps Hub (5G16AINDS-USB-A-HUB) • 10-Port Industrial USB 5Gbps Hub (ST1030USBM) • 7-Port Industrial USB 5Gbps Hub (ST7300USBME) • 7-Port Industrial USB 2.0 (480Mbps) Hub (HB20A7AME) • 7-Port Industrial USB 2.0 (480Mbps) Hub with Extended Temperature Range (ST7200USBM) • 4-Port Industrial USB 2.0 (480Mbps) Hub with Extended Temperature Range (HB20A4AME) • 4-Port Industrial USB 2.0 (480Mbps) Hub (ST4200USBM) This power adapter can also be used to replace a lost or broken power adapter, or can be kept as a redundant back-up power brick for mission critical applications for StarTech.com Industrial USB Hubs that include a power adapter, such as: • 10-Port USB 5Gbps Industrial Hub (HB30A10AME) • 7-Port USB 5Gbps Industrial Hub (HB30A7AME) • 4-Port Industrial USB 5Gbps Hub (ST4300USBM)
- StarTech.com 160W Universal DC Power Adapter (24V/6.6A), 2-Wire Cord and 2/3-Pin Terminal Blocks, 100-240V AC/DC External Power Supply for Industrial USB Hubs, NA/UK/EU/ANZ Cords - 4ft/1.2m DC Power Cord (160W-POWER-ADAPTER) - power adapter - 158.4 Watt
- Power adapter - external
- 291 g
- Localisation
- Australia, New Zealand, North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- DC 24 V
- Power Capacity
- 158.4 Watt
- Included Accessories
- 4 power cords, two conductor terminal block connector (attached), three conductor terminal block connector
- Black
- 5.3 cm x 11.5 cm x 3.7 cm
- 2-year warranty
- Black
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- DC 24 V
- Max Electric Current
- 6.6 A
- Power Capacity
- 158.4 Watt
- Cables Included
- DC power cable - integrated - 1.2 m
- Plastic housing
- UL, FCC, RoHS, PSE Mark, REACH
- Limited warranty - 2 years
- 5 °C
- 55 °C
- 20 - 80%
- 5.3 cm
- 11.5 cm
- 3.7 cm
- 291 g
- Shipping Width
- 16 cm
- Shipping Depth
- 9 cm
- Shipping Height
- 20 cm
- Shipping Weight
- 350 g
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £103.00 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £111.24 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £131.40 |
StarTech.com 7-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply | In Stock | £124.76 |
StarTech.com 10-Pt Industrial USB 3.0 Hub w/ Ext. Power Supply | In Stock | £164.00 |
