StarTech.com DC Power Adapter - 12V, 6.5A
Quicklinx: CWSKWS00 Mfr#: SVA12DN4NEUA
Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has a 4-pin DIN barrel and requires 12 volts and up to 6.5 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
This power adapter is a direct replacement for the power adapters included with the following StarTech.com products: USB 3.0 / eSATA 4-Bay 3.5in SATA III Hard Drive Enclosure (S3540BU33E); 1U Rackmount 4-Bay 3.5in SATA / SAS External Hard Drive Enclosure (SAT35401U); 4 Bay eSATA USB 3.0 to SATA Hard Drive Docking Station (SATDOCK4U3E); 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock (SATDOCK4U3RE); USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station (SDOCK4U33).
StarTech 12V, 6.5A DC Adapter - Universal - 78W - DC Adapter - Power Adapter (SVA12DN4NEUA) - power adapter
Power adapter - external
Australia, Japan, United Kingdom, Europe, North Asia
Input Voltage
AC 120-230 V
Output Voltage
12 V
P/N: S3540BU33E, SATDOCK4U3RE, SDOCK4U33
Input Voltage
AC 120-230 V
Output Voltage
12 V
Max Electric Current
6.5 A
Power cable - external
RoHS
60 °C
0 - 80%
CWSK StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
CWSK StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £416.04
CWSK StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans In Stock £76.10
CWSK StarTech.com DC Power Adapter - 9V, 2A In Stock £12.21
CWSK StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
CWSK StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
CWSK StarTech.com DC Power Adapter - 5V, 2A In Stock £9.91
CWSK StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
