Convert a DB9 female connector into an RJ45 female connector. The GC98MF Modular Adapter features a DB9 male connector and an RJ45 female connector. Used for modular RS232, RS422 and RS485 connections, the adapter converts a DB9 female connection into an RJ45 female connection. The adapter allows for custom serial pin out configurations.
- StarTech.com DB9 to RJ45 Modular Adapter - M/F - Serial adapter - DB-9 (M) to RJ-45 (F) - GC98MF - serial adapter
- Serial adapter
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- RJ-45 - female
- Limited lifetime warranty
- Designed For
- StarTech.com 16 Port Enhanced RS232 Serial Console Server
- Network Cable Type
- Serial adapter
- Connector
- RJ-45 - female
- Designed For
