StarTech.com DB9 to RJ45 Modular Adapter - F/F
Quicklinx: 3ZNCWS00 Mfr#: GC98FF
More than 50 In Stock
£4.69 ex VAT
£5.62 inc VAT
Only the best-quality components are used when StarTech.com's expert manufacturing team creates the cable supplies and this gender changer is no different. The adapter DB25M to RJ45F is used for modular RS232, RS422, and RS485 connections.
  • Versatile connectivity
    This adapter allows users to connect devices with DB-9 interfaces to RJ-45 networks, enhancing compatibility.
  • Durable design
    Constructed with robust materials, the adapter is built to withstand usage while maintaining reliable performance.
  • Easy installation
    The straightforward design of the adapter enables quick setup, ensuring efficient use in any technical environment.
StarTech.com DB9 to RJ45 Modular Adapter - F/F - Serial adapter - DB-9 (F) to RJ-45 (F) - GC98FF - serial adapter - DB-9 to RJ-45
Serial adapter
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
RJ-45 - female
P/N: ICUSB2324852, ICUSB422
Serial adapter
Connector
RJ-45 - female
