Only the best-quality components are used when StarTech.com's expert manufacturing team creates the cable supplies and this gender changer is no different. The adapter DB25M to RJ45F is used for modular RS232, RS422, and RS485 connections.
Versatile connectivity
This adapter allows users to connect devices with DB-9 interfaces to RJ-45 networks, enhancing compatibility. -
Durable design
Constructed with robust materials, the adapter is built to withstand usage while maintaining reliable performance. -
Easy installation
The straightforward design of the adapter enables quick setup, ensuring efficient use in any technical environment.
- StarTech.com DB9 to RJ45 Modular Adapter - F/F - Serial adapter - DB-9 (F) to RJ-45 (F) - GC98FF - serial adapter - DB-9 to RJ-45
- Serial adapter
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- RJ-45 - female
- Limited lifetime warranty
- Designed For
- P/N: ICUSB2324852, ICUSB422
- Serial adapter
- Connector
- RJ-45 - female
- Designed For
