StarTech.com DB9 to DB25 Serial Cable Adapter - F/M
Quicklinx: 8CF1WS00 Mfr#: AT925FM
More than 50 in stock
£4.18 ex VAT
£5.01 inc VAT
Only the best-quality components are used when StarTech.com's expert manufacturing team creates cable supplies and this adapter is no different. The adapter DB9F to DB25M converts a 9 pin serial port to a 25 pin male connector.
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M - Serial adapter - DB-9 (F) to DB-25 (M) - AT925FM - serial adapter
Serial adapter
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
25 pin D-Sub (DB-25) - male
P/N: EC1S232U2, ICUSB232C, ICUSB232PROC, ICUSB232SM3, ICUSBANDR232, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S553, PEX2S553LP, PEX2S952, PEX2S952LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP, PEX8S952
Serial adapter
Connector
P/N: 10PKPCI1S550, EC1S232U2, IC485S, ICUSB232, ICUSB232C, ICUSB232PROC, ICUSB232SM3, ICUSBANDR232, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI1S550, PCI2S1P, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S553, PEX2S553LP, PEX2S952, PEX2S952LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP, PEX8S952
Price Range Ex VAT: 0 - 50
