Convert a DB25 male port into a DB9 male connector. This DB25 to DB9 Serial Adapter converts a 25-pin serial port to a 9 pin male connector.
The DB25 to DB9M Serial Adapter is designed for durable, reliable performance and connectivity.
Durable construction
Constructed with high-quality materials to ensure longevity and reliability for all connections. -
Easy installation
Simple Plug-and-Play functionality allows for quick and hassle-free setup without additional configurations.
- StarTech.com DB9 to DB25 Serial Adapter - M/F - Serial adapter - DB-9 (M) to DB-25 (F) - AT925MF - serial adapter - DB-9 to DB-25
- Serial adapter
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 25 pin D-Sub (DB-25) - female
- Limited lifetime warranty
- Designed For
- StarTech.com 4 Port PCI RS232 Serial Adapter Card High Speed 16950 cable included, Serial Adapter Card
- Serial adapter
- Connector
- Designed For
