StarTech.com DB9 to DB25 Serial Adapter - M/F
Quicklinx: 8CF2WS00 Mfr#: AT925MF
10 In Stock
£5.22 ex VAT
£6.26 inc VAT
Convert a DB25 male port into a DB9 male connector. This DB25 to DB9 Serial Adapter converts a 25-pin serial port to a 9 pin male connector.
The DB25 to DB9M Serial Adapter is designed for durable, reliable performance and connectivity.
  • Durable construction
    Constructed with high-quality materials to ensure longevity and reliability for all connections.
  • Easy installation
    Simple Plug-and-Play functionality allows for quick and hassle-free setup without additional configurations.
StarTech.com DB9 to DB25 Serial Adapter - M/F - Serial adapter - DB-9 (M) to DB-25 (F) - AT925MF - serial adapter - DB-9 to DB-25
Serial adapter
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
25 pin D-Sub (DB-25) - female
StarTech.com 4 Port PCI RS232 Serial Adapter Card High Speed 16950 cable included, Serial Adapter Card
Serial adapter
Connector
