This null modem cable adapter features one DB9 male and one DB9 female connector - a cost-saving way to convert a straight through cable into a null modem cable.
Versatile connectivity
This null modem adapter allows for direct serial communication between devices by providing a male to female connection using 9-pin D-Sub (DB-9) connectors. -
Robust construction
Designed with durability in mind, this adapter maintains a stable connection, essential for effective data transmission in various applications.
 - StarTech.com DB9 RS232 Serial Null Modem Adapter - Null modem adapter - DB-9 (M) to DB-9 (F) - NM9MF - null modem adapter - DB-9 to DB-9
- Connector
 - 9 pin D-Sub (DB-9) - male
- Connector (Second End)
 - 9 pin D-Sub (DB-9) - female
 - Limited lifetime warranty
- Designed For
 - P/N: EC1S952, EC2S952, PCI2S232485I, PCI2S4851050, PCI2S5502, PEX4S953LP
- Connector
- Designed For
