StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F
Quicklinx: 76PBWS00 Mfr#: NM9MF
10 In Stock
£5.19 ex VAT
£6.22 inc VAT
This null modem cable adapter features one DB9 male and one DB9 female connector - a cost-saving way to convert a straight through cable into a null modem cable.
  • Versatile connectivity
    This null modem adapter allows for direct serial communication between devices by providing a male to female connection using 9-pin D-Sub (DB-9) connectors.
  • Robust construction
    Designed with durability in mind, this adapter maintains a stable connection, essential for effective data transmission in various applications.
StarTech.com DB9 RS232 Serial Null Modem Adapter - Null modem adapter - DB-9 (M) to DB-9 (F) - NM9MF - null modem adapter - DB-9 to DB-9
Null modem adapter
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: EC1S952, EC2S952, PCI2S232485I, PCI2S4851050, PCI2S5502, PEX4S953LP
Null modem adapter
Connector
76PB StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F In Stock £5.52
