Organize your cables in any rack or cabinet that's 40U or larger, using this vertical cable management panel. This 6-foot vertical cable manager (2 x 3-foot panels) gives you a simple and space-efficient way to organize the cables in your server rack. You can attach the two-panel cable manager vertically into your rack, to neatly guide cables between equipment that's mounted at different heights.
The 0U cable manager offers versatile installation options and is compatible with most racks that are 40U or larger. The panels feature a 0U design that doesn't take up any mounting space, and with simple tool-less installation they're easy to attach or reposition as necessary.
The cable manager uses a D-ring method of cable management that neatly guides cables running through it. Having well organized and routed cables not only improves the appearance and accessibility of your rack, it also makes it easier for you to install, access and maintain rack components.
This versatile cable management system consists of two 3-foot panels, so you can configure each panel as needed to accommodate all of your equipment. You can install the individual panels end to end (top to bottom), so that they span the height of your rack, or on either side or the front and back of your rack to manage cables in multiple locations.
The two-piece cable manager runs vertically along the side of your rack, to neatly guide cables between equipment that's mounted at different heights. This provides a tidy and well-organized way to run cables from devices mounted toward the bottom of your rack to other devices mounted near the top, without leaving a mess of cables hanging in between.
For maximum compatibility with virtually any server rack, you can install the cable-management panels using mounting holes that are commonly found on most rack equipment. The tool-less mounting method attaches the cable management panel to the keyhole-shaped mounting holes that are built into your rack.
The horizontal mounting rail method attaches the cable management panel to the horizontal mounting rails that run along the side of your rack.
For racks that don't support these installation methods, you can also mount the cable management panels through other means, such as using the non-standardized holes found on your rack walls and enclosures, or the rack units on equipment mounting rails.
Routing your cables through a panel reduces the tension that's often put on cables. This prevents cable damage or connection loss, and reduces strain on equipment ports, preventing damage to your expensive rack-mounted devices.
Properly routing cables also improves airflow, which passively cools devices stored in your rack, helping to keep your equipment running at optimal temperatures to reduce the probability of damage caused by your rack overheating.
Durable construction
Made from high-quality steel, this cable management kit offers durability and reliability for use in demanding environments. -
Efficient organization
The D-ring hooks provide a streamlined way to organize cables, reducing clutter and improving airflow within the server rack. -
Flexible installation
This kit allows for both front and rear mounting, enabling users to customize their setup based on available space and requirements. -
Ample height compatibility
With a capacity of 40U, this cable management solution fits a range of server rack configurations, accommodating diverse setups. -
Complete package
Included with the kit are screws and washers, ensuring that users have everything needed for installation.
- Startech Vertical 0U Server Rack Cable Management w/ D-Ring Hooks - 40U Network Rack Cord Manager Panels - 2x 3ft Wire Organizers (CMVER40UD) - D-ring cable management kit - 40U
- Product Type
- Package Content
- 4 x screws, washers
- Length
- 1.83 m
- Product Material
- Steel
- Black
- Height (Rack Units)
- 40U
- 2-year warranty
- Designed For
- P/N: RK2537BKM, RK4242BK24, RK4242BK30
- Product Type
- Package Content
- Product Material
- Steel
- 40U
- Length
- 1.83 m
- Enclosure Colour
- Black
- Rack Mounting Kit
- Included
- Rear mountable, vertical orientation, front mountable
- Quantity of Items per Pack
- 2
- Limited warranty - 2 years
- Designed For
StarTech.com D-Ring Hook Cable Panel - 6ft. | In Stock | £70.14 |
StarTech.com D-Ring Hook Cable Panel - 3ft. | In Stock | £39.24 |
StarTech.com Finger Duct Cable Panel - 6ft. | In Stock | £90.20 |
StarTech.com Finger Duct Cable Panel - 3ft. | In Stock | £47.31 |
StarTech.com 1U Rack-Mount Cable Lacing Bar | In Stock | £11.81 |
