- StarTech.com Corner Sit Stand Desk Converter with Keyboard Tray, Large Surface 35" x 21", Height Adjustable Ergonomic Desktop/Tabletop Standing Workstation, Supports Dual Monitors - Corner Stand Up Desk Converter (ARMSTSCORNR) - standing desk converter - rectangular - black
- Product Type
- Standing desk converter
- Top Surface
- Rectangular - black
- 16 cm - 58.5 cm / adjustable
- 2 years
- Product Type
- Package Content
- Hex key (small), hex key (large), clamp plate, M10 x 50 mm bolt
- Max Load Weight
- 12.7 kg
- Adjustable Height
- Cable Management
Top Surface
- Shape
- Rectangular
- Black
- Size
- 90.8 cm x 53 cm
Base
- Material
- Plastic, MDF, steel
Components
- Details
- Keyboard tray
- 1.1 m
- 70.3 cm
- 16 cm - 58.5 cm
- 9.7 kg
- Dimensions & Weight Details
- Keyboard tray - width: 68 cm, depth: 26.5 cm , Base - width: 90.8 cm, depth: 53 cm
- Shipping Width
- 1.2 m
- Shipping Depth
- 79 cm
- Shipping Height
- 22 cm
- Shipping Weight
- 25.1 kg
- RoHS
- 2 years
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £101.27 |
StarTech.com Ergonomic Monitor Riser Stand | In Stock | £34.72 |
