Dock Your Laptop
During?meetings, you may need?to set up video conference calls using applications such as Microsoft Teams, Zoom or Google Hangouts. Unlike other boardroom conferencing solutions that are limited to only one or two collaboration applications, this module lets you use your own laptop, so you are not restricted to a specific platform. Connect a USB-C or USB-A laptop to the module and access your room's peripherals, webcams, speakers, mics, network and HDMI display. This conference table AV box and docking station module lets you easily connect your laptop with each video conferencing device in your boardroom. You can collaborate with others in the room and around the globe. For users that are unable to dock or for quick access to the display, the front-facing HDMI port lets you connect a laptop directly to the display. -
Easy, Stylish and Clean Installation
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The in-table connectivity box is easy to install in a conference room table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals. KITBZDOCK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Conference Room Docking Station, Universal Laptop Dock, 4K HDMI, 60W Power Delivery, USB Hub, GbE, Audio, In-Table Connectivity Box For Huddle/Boardroom Collaboration Space - For Teams & Zoom Calls - docking station - USB-C / USB 3.0 - HDMI - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB-C / USB 3.0
- Video Interfaces
- HDMI
- 14.5 cm x 10 cm x 11.5 cm
- 1.1 kg
- Black
- Localisation
- North America, Europe, United Kingdom
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 100-240 V
- TAA Compliant
- 2-year warranty
- Product Type
- Docking station
- 14.5 cm
- 10 cm
- 11.5 cm
- 1.1 kg
- Enclosure Colour
- Black
- Localisation
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0, USB 1.1, USB 2.0, USB 3.1 Gen 1
- 2 x display / video - HDMI input - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x microphone - mini-phone 3.5 mm , 1 x headphones / speakers - mini-phone 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (60 W) - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x display / video - HDMI output - 19 pin HDMI Type A
- Cables Included
- 1 x USB-C cable , 1 x USB-A to USB-B cable
- Included Accessories
- Connectivity box (BEZ4MOD), mounting bracket, 4 x M5x20 screws, 8 x #6-32 x 3/16"screws
- 60W power delivery, DisplayPort Alt Mode, full duplex support, auto MDIX support
- DisplayLink Plug and Display, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol), USB Power Delivery 2.0, RoHS, FCC
- TAA Compliant
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V
- OS Required
- Apple macOS 10.14 - 10.15, Apple macOS 11.0, Apple MacOS X 10.9 - 10.12, Google Chrome OS 55 or later, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 2 years
- Shipping Width
- 19 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 13.4 cm
- Shipping Weight
- 3 kg
- 0 °C
- 40 °C
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.44 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.00 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £17.53 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.85 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £19.66 |
StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £24.09 |
StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £35.52 |
StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £9.55 |
