StarTech.com Conference Table Box w/Docking
Quicklinx: GKNHWS00 Mfr#: KITBZDOCK
£357.64 ex VAT
£429.16 inc VAT
Conference Room Docking Station - 4K HDMI - USB-C and USB-A - USB-C Power Delivery.
  • Dock Your Laptop
    During?meetings, you may need?to set up video conference calls using applications such as Microsoft Teams, Zoom or Google Hangouts. Unlike other boardroom conferencing solutions that are limited to only one or two collaboration applications, this module lets you use your own laptop, so you are not restricted to a specific platform. Connect a USB-C or USB-A laptop to the module and access your room's peripherals, webcams, speakers, mics, network and HDMI display. This conference table AV box and docking station module lets you easily connect your laptop with each video conferencing device in your boardroom. You can collaborate with others in the room and around the globe. For users that are unable to dock or for quick access to the display, the front-facing HDMI port lets you connect a laptop directly to the display.
  • Easy, Stylish and Clean Installation
    Design a practical and stylish solution that impresses your visitors and facilitates their needs. The in-table connectivity box is easy to install in a conference room table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals. KITBZDOCK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Conference Room Docking Station, Universal Laptop Dock, 4K HDMI, 60W Power Delivery, USB Hub, GbE, Audio, In-Table Connectivity Box For Huddle/Boardroom Collaboration Space - For Teams & Zoom Calls - docking station - USB-C / USB 3.0 - HDMI - 1GbE - TAA Compliant
Docking station
Docking Interface
USB-C / USB 3.0
Video Interfaces
HDMI
14.5 cm x 10 cm x 11.5 cm
1.1 kg
North America, Europe, United Kingdom
Gigabit Ethernet
Power adapter AC 100-240 V
TAA Compliant
Docking station
14.5 cm
10 cm
11.5 cm
1.1 kg
Enclosure Colour
Video
Max Resolution Details
3840 x 2160 - 30 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0, USB 1.1, USB 2.0, USB 3.1 Gen 1
2 x display / video - HDMI input - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x microphone - mini-phone 3.5 mm , 1 x headphones / speakers - mini-phone 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (60 W) - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x display / video - HDMI output - 19 pin HDMI Type A
1 x USB-C cable , 1 x USB-A to USB-B cable
Connectivity box (BEZ4MOD), mounting bracket, 4 x M5x20 screws, 8 x #6-32 x 3/16"screws
60W power delivery, DisplayPort Alt Mode, full duplex support, auto MDIX support
DisplayLink Plug and Display, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol), USB Power Delivery 2.0, RoHS, FCC
TAA Compliant
Power adapter
AC 100-240 V
Apple macOS 10.14 - 10.15, Apple macOS 11.0, Apple MacOS X 10.9 - 10.12, Google Chrome OS 55 or later, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Shipping Width
19 cm
Shipping Depth
19.2 cm
Shipping Height
13.4 cm
Shipping Weight
3 kg
GKNH StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.74
GKNH StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £17.01
GKNH StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £21.34
GKNH StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GKNH StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
GKNH StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.29
GKNH StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £25.51
GKNH StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £38.11
GKNH StarTech.com 0.5m Premium 4K HDMI Cable In Stock £10.29
