Interconnect Box , HDMI, VGA and DisplayPort Inputs , HDMI Output. This conference table connectivity box for A/V installs in your table or lectern to provide A/V, networking, and USB charging connectivity in your boardroom, auditorium, or classroom. The box makes it easy to connect HDMI, DisplayPort and VGA laptops to your room's large HDMI display, and provides LAN and USB power connectivity for charging USB devices. The box also provides some boardroom cable management by hiding connectivity cables in your table.
The table box enables presenters in your conference room to easily share their laptop screen on the room's large display or projector, with supported resolutions up to 4K 30Hz.
To share video from virtually any laptop, the table box supports HDMI, VGA and DisplayPort inputs and automatically outputs the most recently connected input to the HDMI display.
Enabling visitors in your conference room to charge their iPhone, iPad, smartphone, or tablet, the table box features three USB charge ports. Plus, the box features an Ethernet pass-through port to provide secure wired network connectivity in rooms where Wi-Fi isn't available.
The boardroom interconnect box has an aluminum finish that complements your space. The hideaway panel eliminates clutter by discreetly covering the connection ports when they're not in use.
- StarTech.com Conference Table Connectivity Pop up Box with AV and Data Ports - HDMI, VGA, DisplayPort to 4K HDMI Output (BOX4HDECP2) - mounting plate
- Product Type
- Mounting plate - HD-15, RJ-45, mini-phone stereo 3.5 mm, HDMI, USB Type A, DisplayPort
- Package Content
- 2 mounting brackets, 2 x screws, external power adapter, tie bracket, die cut outline
- 17 cm x 10 cm x 10 cm
- 1.1 kg
- Silver
- Localisation
- Australia, Japan, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Product Type
- Mounting plate
- Package Content
- 17 cm
- 10 cm
- 10 cm
- 1.1 kg
- Enclosure Colour
- Silver
- Localisation
Cabling & Wiring
- Connector Provided
- 1 x 19 pin HDMI Type A male , 2 x RJ-45 female , 1 x 19 pin HDMI Type A female , 1 x 15 pin HD D-Sub (HD-15) female , 1 x mini-phone stereo 3.5 mm female , 1 x 20 pin DisplayPort female , 3 x 4 pin USB Type A female
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.23 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.14 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £17.97 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.72 |
