Convert and Scale a Composite or S-Video Signal to Work with a VGA Display. The VID2VGATV2 Composite and S-Video to VGA Video Scan Converter (with Scaler) provides a simple way to convert Composite or S-Video signals to VGA (or Component RCA) output, for use with computer monitors, projectors or HDTV sets. Equipped with an On-Screen Display (OSD) menu and dip switches for simple configuration and selection of your video output settings, this compact video scaler installs quickly and easily for a true plug-and-play experience. An integrated scaler circuit dynamically converts the S-Video or Composite video input signal, giving you multiple output resolutions to choose from, to ensure compatibility with your display or projector. Plus, the Component/S-Video-VGA Converter includes a VGA to Component (RCA) breakout cable, which enables you to connect to TV sets that are not equipped with a VGA port.
Versatile connectivity options
This converter features connectors for 4-pin mini-DIN, 15-pin HD D-Sub, and RCA, allowing connection to a variety of devices for greater flexibility in setups. -
High-resolution support
It supports resolutions up to UXGA and HDTV, enabling clear and detailed video output for enhanced viewing experiences. -
Environmentally friendly design
Operates efficiently within a temperature range of 0 °C to 40 °C and humidity levels of 0 to 60%, making it suitable for varied environments.
- StarTech.com Composite and S-Video to VGA Video Scan Converter - composite to VGA - scan Converter - s-Video to VGA (VID2VGATV2) - video converter - black
- Video converter
- Graphics Engine
- - up to
- 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video output - RCA x 3 (with adapter)
- 6.4 cm x 11.2 cm x 2.6 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: SVA5M3NEUA
- Video converter
- 1 x S-video input - 4 pin mini-DIN - female , 1 x composite video input - RCA - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x component video output - RCA x 3 (with adapter) - male
Video Output
- Supported Display Graphics
- XGA (1024x768), SXGA (1280x1024), UXGA (1600x1200), HDTV (1920x1080)
- Analogue Video Format
- NTSC, PAL
- Cables Included
- 1 x VGA / component video adapter - 91.44 cm
- Plug and Play
- 6.4 cm
- 11.2 cm
- 2.6 cm
- 90 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 60%
- Designed For
- P/N: SVA5M3NEUA
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV | In Stock | £85.18 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.01 |
