StarTech.com Composite and S-Video to HDMI Converter with Audio
Quicklinx: 7X1JWS00 Mfr#: VID2HDCON
Type: Signal Converter
  • High-Definition Multimedia Interface (HDMI)
Hurry, only 2 left in stock!
£102.84 ex VAT
£123.40 inc VAT
Convert a Composite or S-Video Signal and the Accompanying Audio to HDMI?. The VID2HDCON Composite and S-Video to HDMI? Video Converter (with Audio) lets you connect an S-Video or Composite device, along with supporting 3.5mm audio, to your HDMI monitor or television. Equipped with convenient selector switches for easy configuration, the S-Video/Composite to HDMI converter is able to function with both NTSC and PAL systems, and offers support for output resolutions up to 1600x1200 (PC) or 1080p (TV) to seamlessly integrate with almost any display. The converter features an integrated 3.5mm audio connection that enables sending the output through a single HDMI cable to your destination display, avoiding the hassle of running a separate audio cable.
StarTech.com Composite and S-Video to HDMI Converter with Audio - video converter - black
Video converter
Max Resolution
1600 x 1200
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI output - 19 pin HDMI Type A
16.3 cm x 16.5 cm x 3.4 cm
Enclosure Colour
Video converter
Max Resolution
1600 x 1200 at 60 Hz
1 x composite video input - RCA - female , 1 x S-video input - 4 pin mini-DIN - female , 1 x audio line-in - mini-phone stereo 3.5 mm - female , 1 x HDMI output - 19 pin HDMI Type A - female
LED indicator
Video Output
Analogue Video Format
NTSC, PAL
AC 120/230 V / DC 5 V
2.5 Watt
1 x power adapter
Plug and Play, FCC, RoHS
16.3 cm
16.5 cm
3.4 cm
100 g
Enclosure Colour
20 - 90%
7X1J StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £3.65
7X1J StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £70.89
7X1J StarTech.com S-Video / Composite to USB Video Capture Cable w/ TWAIN and Mac Support In Stock £28.04
7X1J StarTech.com Composite and S-Video to HDMI Converter with Audio In Stock £102.84
7X1J StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £2.87
Price Range Ex VAT: 100 - 150
