Connect a Component video source device with supporting audio to your HDMI display. The CPNTA2HDMI Component to HDMI Video Converter with Audio lets you convert and combine analog component video (YPbPr and YCbCr) with corresponding audio (digital or analog) into a single HDMI output.
The component to HDMI converter supports high definition video resolutions of up to 1080p and 5.1 channel audio, providing the quality and convenience of HDMI without the expense of having to upgrade output devices for HDMI compatibility.
Seamless integration
The Converge A/V Component with Audio to HDMI Format Converter bridges the gap between component video and HDMI, offering a smooth transition for devices with differing connection types. Its external form factor ensures easy setup and integration into any setup. -
High-quality audio and video
Supporting resolutions up to 1920 x 1080 and a V-Sync rate of 60 Hz, this video converter delivers crisp, clear high-definition visuals and audio through HDMI output, enhancing your viewing experience. -
Versatile connectivity
Equipped with multiple input ports including component video, SPDIF line-in, and a mini-phone stereo 3.5 mm for audio, this converter ensures compatibility with a wide range of devices, making it a versatile addition to your tech toolkit.
- StarTech.com Converge A/V Component with Audio to HDMI® Format Converter - Video converter - HDMI ( HDCP ) (CPNTA2HDMI) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x component video input - RCA x 3 , 1 x SPDIF line-in - RCA , 1 x HDMI output - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm
- 7.7 cm x 10 cm x 3 cm
- Enclosure Colour
- Black
- 1-year warranty
- Video converter
- Max Resolution
- 1920 x 1080 at 60 Hz
- 1 x component video input - RCA x 3 - female , 1 x SPDIF line-in - RCA - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x audio line-in - mini-phone stereo 3.5 mm - female
- HDCP
- Voltage Required
- DC 5 V
- Cables Included
- 1 x audio cable
- FCC, RoHS
- 7.7 cm
- 10 cm
- 3 cm
- Enclosure Colour
- Black
- Limited warranty - 1 year
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
