Connect your VGA or Component video source to an HDMI display. The VGA2HD2 Component/VGA to HDMI Video Converter offers seamless conversion from an analog VGA or Component video source, such as a Computer, DVR, or DVD player, to a digital HDMI output.
The converter helps reduce equipment costs by eliminating the need to upgrade individual analog components, by offering a solution that converts an analog video source (RGB/YPbPr) for use with a digital HDMI display.
This versatile analog-digital converter not only supports resolutions up to 1920x1200 including high-definition 1080p, but also enables you to convert and combine an analog RCA audio source into its digital HDMI output signal.
Versatile connectivity
This converter bridges the gap between older and newer technology, allowing users to connect VGA and component video sources to an HDMI display. It's an ideal solution for utilizing legacy computers and devices with modern HDMI-equipped monitors and projectors. -
High-quality video support
Supporting resolutions up to 1080p (HDTV) and 1920 x 1200 (PC), the converter ensures a high-quality viewing experience. Whether it's for professional presentations or home entertainment, users can expect clear, vibrant images without compromise. -
Easy installation
Designed for simplicity, this converter requires no software or drivers for setup. It's a Plug-and-Play solution that makes it easy for users to integrate into their existing setups, ensuring a seamless transition and minimal downtime.
- StarTech.com Component (YPbPr) / VGA To HDMI Converter With Audio - PC to HDMI - resolutions up to 1080p (HDTV) and 1920 x 1200 (PC) (VGA2HD2) - video converter - black
- Video converter
- Graphics Engine
- - up to
- 1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x component video input - RCA x 3 (on supplied cable)
- 7.6 cm x 3 cm x 9.2 cm
- Enclosure Colour
- Black
- Localisation
- United States
- 2-year warranty
- Video converter
- 1 x audio line-in - RCA x 2 - female , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x component video input - RCA x 3 (on supplied cable) - male
- Cables Included
- 1 x component video cable
- FCC, RoHS
- 7.6 cm
- 3 cm
- 9.2 cm
- 190 g
- Enclosure Colour
- Black
- Localisation
- United States
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90%
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £8.55 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p | In Stock | £36.80 |
StarTech.com DisplayPort VGA HDMI Converter Switch | In Stock | £150.51 |
StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio | In Stock | £29.98 |
