StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200
Quicklinx: 8GN6WS00 Mfr#: VGA2HD2
Type: AV Sender
£84.12 ex VAT
£100.94 inc VAT
Connect your VGA or Component video source to an HDMI display. The VGA2HD2 Component/VGA to HDMI Video Converter offers seamless conversion from an analog VGA or Component video source, such as a Computer, DVR, or DVD player, to a digital HDMI output.
The converter helps reduce equipment costs by eliminating the need to upgrade individual analog components, by offering a solution that converts an analog video source (RGB/YPbPr) for use with a digital HDMI display.
This versatile analog-digital converter not only supports resolutions up to 1920x1200 including high-definition 1080p, but also enables you to convert and combine an analog RCA audio source into its digital HDMI output signal.
  • Versatile connectivity
    This converter bridges the gap between older and newer technology, allowing users to connect VGA and component video sources to an HDMI display. It's an ideal solution for utilizing legacy computers and devices with modern HDMI-equipped monitors and projectors.
  • High-quality video support
    Supporting resolutions up to 1080p (HDTV) and 1920 x 1200 (PC), the converter ensures a high-quality viewing experience. Whether it's for professional presentations or home entertainment, users can expect clear, vibrant images without compromise.
  • Easy installation
    Designed for simplicity, this converter requires no software or drivers for setup. It's a Plug-and-Play solution that makes it easy for users to integrate into their existing setups, ensuring a seamless transition and minimal downtime.
StarTech.com Component (YPbPr) / VGA To HDMI Converter With Audio - PC to HDMI - resolutions up to 1080p (HDTV) and 1920 x 1200 (PC) (VGA2HD2) - video converter - black
Video converter
Graphics Engine
- up to
1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x component video input - RCA x 3 (on supplied cable)
7.6 cm x 3 cm x 9.2 cm
Enclosure Colour
United States
Video converter
1 x audio line-in - RCA x 2 - female , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x component video input - RCA x 3 (on supplied cable) - male
1 x component video cable
FCC, RoHS
7.6 cm
3 cm
9.2 cm
190 g
Enclosure Colour
United States
20 - 90%
8GN6 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
8GN6 StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £85.18
8GN6 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
8GN6 StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p In Stock £37.39
8GN6 StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £150.51
8GN6 StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio In Stock £30.45
Type: AV Sender
