Connect an HDMI device/computer to a VGA monitor or projector, with this slim adapter ideal for laptops/Ultrabooks. The HD2VGAMICRO HDMI to VGA converter lets you connect an HDMI output from your Ultrabook, Chromebook or laptop computer to a VGA monitor or projector.
With no external power adapter required, and a small form factor design, this portable HDMI to VGA adapter is a great accessory to have on-hand in your laptop carrying case. Plus, this easy-to-use converter supports plug-and-play installation, which speeds up installation time eliminates hassle.
The converter delivers maximum video quality, with support for resolutions up to 1920x1200/1080p - a convenient solution for boosting productivity by extending your computer's desktop onto to a secondary monitor.
Versatile compatibility
This adapter converts HDMI signals to VGA, allowing users to connect modern devices to older VGA displays, making it suitable for different environments. -
High output resolution
With support for resolutions up to 1920 x 1200, this adapter delivers a clear and detailed image, enhancing visual experiences for presentations and media. -
Active adapter design
The active adapter design ensures reliable signal conversion, reducing issues with compatibility while maintaining quality performance. -
Efficient refresh rate
The 60 Hz refresh rate provides smooth video output, making it ideal for both still images and dynamic content. -
Compliance assured
Compliant with several standards such as FCC and RoHS, this adapter ensures adherence to safety and environmental regulations.
- StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops - 1920x1200/1080p - adapter - HDMI / VGA - 4.5 cm
- Cable
- Adapter - HDMI / VGA
- Max Output Resolution
- 1920 x 1200 - 60 Hz
- Length
- 4.5 cm
- Black
- Connector
- HDMI - male (input)
- Connector (Second End)
- HD-15 (VGA) - female
- Active adapter
- 3-year warranty
- Designed For
- P/N: DKT30CSDHPD3, SV211HDUC, SV221HUC4K
- Cable Type
- Adapter active
- Interface Supported
- HDMI / VGA
- Length
- 4.5 cm
- Slim
- Black
Adapters & Converters
- 1920 x 1200
- Refresh Rate
- 60 Hz
- Connector
- 19 pin HDMI Type A - male (input)
- 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS, WEEE, REACH, RCM
- 2.1 cm
- 1.4 cm
- Shipping Width
- 17.5 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 11 g
- Limited warranty - 3 years
- Designed For
StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p | In Stock | £14.03 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.81 |
StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 | In Stock | £22.95 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook | In Stock | £16.15 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £14.78 |
StarTech.com 10ft HDMI to VGA adapter cable | In Stock | £34.95 |
StarTech.com 3ft HDMI to VGA adapter cable | In Stock | £17.68 |
StarTech.com 6ft HDMI to VGA adapter cable | In Stock | £20.08 |
StarTech.com HDMI to VGA Adapter w/ Audio | In Stock | £12.56 |
