Your basket is empty
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops
Quicklinx: 93JPWS00 Mfr#: HD2VGAMICRO
More than 50 in stock
£20.15 ex VAT
£24.18 inc VAT
Standard delivery Delivered within 3-5 working days
Connect an HDMI device/computer to a VGA monitor or projector, with this slim adapter ideal for laptops/Ultrabooks. The HD2VGAMICRO HDMI to VGA converter lets you connect an HDMI output from your Ultrabook, Chromebook or laptop computer to a VGA monitor or projector.
With no external power adapter required, and a small form factor design, this portable HDMI to VGA adapter is a great accessory to have on-hand in your laptop carrying case. Plus, this easy-to-use converter supports plug-and-play installation, which speeds up installation time eliminates hassle.
The converter delivers maximum video quality, with support for resolutions up to 1920x1200/1080p - a convenient solution for boosting productivity by extending your computer's desktop onto to a secondary monitor.
StarTech.com Compact HDMI to VGA Adapter Converter video converter - black
Video converter
Video Input
HDMI
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
2.1 cm x 4.5 cm x 1.4 cm
Enclosure Colour
2 years warranty
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
FCC, RoHS
2.1 cm
4.5 cm
1.4 cm
9 g
Enclosure Colour
20 - 90% (non-condensing)
93JP StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.75
93JP StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.20
93JP StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.04
93JP StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £12.11
Price Range Ex VAT: 0 - 50
