Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com Citrix EW3A0000712 Compatible SFP SM Module - 1000Base-LX
Quicklinx: FJMBWS00 Mfr#: EW3A0000712-ST
£6.36 ex VAT
£7.63 inc VAT
The EW3A0000712-ST is a Citrix EW3A0000712 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Citrix EW3A0000712 Compatible SFP Module, 1000BASE-LX, 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, DDM, Mini GBIC - Lifetime Warranty (EW3A0000712-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Citrix EW3A0000712
5.56 cm x 1.37 cm x 1.25 cm
18 g
Plug-in module
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MTBF
634,210,013 hours
FCC, MSA
Citrix EW3A0000712
1.3 Watt
5.56 cm
1.37 cm
1.25 cm
18 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
