The EG3D0000086-ST is a Citrix EG3D0000086 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 550 m (1804 ft).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Citrix EG3D0000086 Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, Mini GBIC Module - Lifetime Warranty (EG3D0000086-ST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- OEM Manufacturer Equivalent Part Number
- Citrix EG3D0000086
- 5.56 cm x 1.37 cm x 1.25 cm
- 16 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 1 Gbps
- 850 nm
- 550 m
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 1000Base-SX - LC multi-mode female x 2
- MTBF
- 629,953,711 hours
- FCC, MSA
- 5.56 cm
- 1.37 cm
- 1.25 cm
- 16 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
