The EG3C0000087-ST is a Citrix EG3C0000087 compatible copper transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000Base-TX compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Citrix EG3C0000087 Compatible SFP Module, 1000BASE-T, SFP to RJ45 (Copper) Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1000Mbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (EG3C0000087-ST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 10Base-T, 1000Base-TX, 100Base-TX
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 100 m
- OEM Manufacturer Equivalent Part Number
- Citrix EG3C0000087
- 6.8 cm x 1.37 cm x 1.38 cm
- 15 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1 Gbps
- 100 m
- Full duplex mode
- 1 x Ethernet 1000Base-TX - RJ-45 female
- MTBF
- 510,469,759 hours
- FCC, RoHS, REACH, MSA
- 6.8 cm
- 1.37 cm
- 1.38 cm
- 15 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
