Add reliable and cost-effective 10 Gigabit Ethernet connections over multimode fiber with this SFP+ module. This StarTech.com 10 Gigabit fiber SFP+ is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the Cisco SFP-10G-SR-S SFP+ transceiver module, as well as other major brands of networking equipment.
This 10GBase-SR SFP+ delivers 10 Gigabit connectivity over multi-mode fiber cable with a range of up to 300 m (984 ft). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit multi-mode SFP+ is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco SFP-10G-SR-S SFP+ transceiver. The StarTech.com SFP+ is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP+ products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in Cisco switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The multi-mode fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 300 m (984 ft), and maximum data rates of up to 10Gbps.
Robust connectivity
Designed as an SFP+ transceiver module, this product provides reliable wired connectivity solutions for demanding networking environments. -
Wide operating range
With an operating temperature range from 0°C to 70°C and humidity tolerance of 5 - 95%, the module functions effectively in various conditions. -
Compliance and standards
This module adheres to multiple compliance standards including UL, FCC, RoHS, and MSA, ensuring its safety and interoperability.
- StarTech.com Cisco SFP-10G-SR-S Compatible SFP+ Module, 10GBASE-SR, 10GbE MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 300m, 850nm, DDM, Cisco Firepower, ASR9000, C9300 - Lifetime Warranty (SFP10GSRSST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-10G-SR-S
- 1.39 cm x 5.84 cm x 1.26 cm
- 30 g
- 2-year warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 850 nm
- 300 m
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3ae
- 1 x Ethernet 10GBase-LR - LC multi-mode female x 2
- UL, FCC, RoHS, MSA
- 1.39 cm
- 5.84 cm
- 1.26 cm
- 30 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 95%
StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £18.69 |
StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £21.15 |
StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £33.25 |
StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £16.47 |
StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £24.53 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £301.73 |
