StarTech.com Cisco SFP-10G-ER Compatible SFP+ SM Module - 10GBase-ER
Quicklinx: FLYNWS00 Mfr#: SFP-10G-ER-ST
The SFP-10G-ER-ST is a Cisco SFP-10G-ER compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-ER compliant networks, with a maximum distance of up to 40 km (24.8 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Cisco SFP-10G-ER Compatible SFP+ Module - Lifetime Warranty (SFP10GERST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-ER
Data Transfer Rate
10 Gbps
Optical Wave Length
1550 nm
10GbE
Max Transfer Distance
40 km
Cisco SFP-10G-ER
1.39 cm x 5.84 cm x 1.26 cm
30 g
Plug-in module
Silver
Wired
Cabling Type
10GBase-ER
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1550 nm
40 km
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-ER - LC single-mode female x 2
UL, FCC, RoHS, MSA
Cisco SFP-10G-ER
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
FLYN StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £288.42
