The SFP-10G-ER-ST is a Cisco SFP-10G-ER compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-ER compliant networks, with a maximum distance of up to 40 km (24.8 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Cisco SFP-10G-ER Compatible SFP+ Module - Lifetime Warranty (SFP10GERST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-ER
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1550 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 40 km
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-10G-ER
- 1.39 cm x 5.84 cm x 1.26 cm
- 30 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-ER
- 10GbE
- 10 Gbps
- 1550 nm
- 40 km
- Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-ER - LC single-mode female x 2
- UL, FCC, RoHS, MSA
- Cisco SFP-10G-ER
- 1.39 cm
- 5.84 cm
- 1.26 cm
- 30 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 95%
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
