StarTech.com Cisco SFP-10G-BXU-I SFP+ Module
Quicklinx: FHL3WS00 Mfr#: SFP-10G-BXU-I-ST
The SFP-10G-BXU-I-ST is a Cisco SFP-10G-BXU-I compatible upstream fiber SFP transceiver which pairs with StarTech.com's SFP-10G-BXD-I-ST. They are designed, programmed and tested to work with 10GBase-BX compatible Cisco switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Cisco SFP-10G-BXU-I Compatible SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+, LC 10km, Cisco ASR9000ASR1000, NCS5500 Mini GBIC - Lifetime Warranty (SFP-10G-BXU-I-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-BX-U
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10GbE
Max Transfer Distance
10 km
Cisco SFP-10G-BXU-I
5.84 cm x 1.39 cm x 1.26 cm
24 g
Plug-in module
Wired
Cabling Type
10GBase-BX-U
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-BX-U - LC single-mode female
MSA
Cisco SFP-10G-BXU-I
1.3 Watt
5.84 cm
1.39 cm
1.26 cm
24 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
