The SFP-10G-BXU-I-ST is a Cisco SFP-10G-BXU-I compatible upstream fiber SFP transceiver which pairs with StarTech.com's SFP-10G-BXD-I-ST. They are designed, programmed and tested to work with 10GBase-BX compatible Cisco switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Cisco SFP-10G-BXU-I Compatible SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+, LC 10km, Cisco ASR9000ASR1000, NCS5500 Mini GBIC - Lifetime Warranty (SFP-10G-BXU-I-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-BX-U
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1270 nm / 1330 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-10G-BXU-I
- 5.84 cm x 1.39 cm x 1.26 cm
- 24 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-BX-U
- 10GbE
- 10 Gbps
- 1270 nm / 1330 nm
- 10 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-BX-U - LC single-mode female
- MSA
- 1.3 Watt
- 5.84 cm
- 1.39 cm
- 1.26 cm
- 24 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
