StarTech.com Cisco QSFP-40G-SR4-S Compatible QSFP+ MM Module - 40GBase-SR
Quicklinx: FHKBWS00 Mfr#: QSFP-40G-SR4-S-ST
Type: Transceiver
£169.24 ex VAT
£203.08 inc VAT
The QSFP-40G-SR4-S-ST is a Cisco QSFP-40G-SR4-S compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 100 m (328 ft).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Cisco QSFP-40G-SR4-S Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multimode Fiber MMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+ MPO 100m, 850nm DDM, Cisco Firepower, - Lifetime Warranty (QSFP-40G-SR4-S-ST) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
100 m
12.2 cm x 1.86 cm x 0.85 cm
37.5 g
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
100 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
244,610,583 hours
MSA
12.2 cm
1.86 cm
0.85 cm
37.5 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
3.5 cm
Shipping Weight
60 g
Limited warranty - lifetime
Type: Transceiver
