StarTech.com Cisco QSFP-40G-CSR4 Compatible QSFP+ MM Module
Quicklinx: FHK7WS00 Mfr#: QSFP-40G-CSR4-ST
Type: Transceiver
£136.47 ex VAT
£163.76 inc VAT
The QSFP-40G-CSR4-ST is a Cisco QSFP-40G-CSR4 compatible fiber transceiver module that has been designed, programmed and tested to work with Arista Networks brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 400 m (1312 ft.).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Cisco QSFP-40G-CSR4 Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multimode Fiber MMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+ MPO 300m, 850nm DDM, Cisco Firepower ASR9000 - Lifetime Warranty (QSFP-40G-CSR4-ST) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
400 m
Cisco QSFP-40G-CSR4
12.2 cm x 1.86 cm x 0.85 cm
37.5 g
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
400 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
95,832,027 hours
MSA
Cisco QSFP-40G-CSR4
12.2 cm
1.86 cm
0.85 cm
37.5 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
3.5 cm
Shipping Weight
60 g
Limited warranty - lifetime
Type: Transceiver
