StarTech.com Cisco Meraki MA-SFP-1GB-SX SFP
Quicklinx: CRGJWS00 Mfr#: MASFP1GBSXST
Type: Modules
13 In Stock
£23.50 ex VAT
£28.20 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over multimode fiber with this SFP module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the Cisco Meraki MA-SFP-1GB-SX transceiver module, as well as other major brands of networking equipment.
This 1000Base-SX SFP delivers Gigabit connectivity over multimode fiber cable, with a range of up to 550 m (1804 ft.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This multimode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The MM Gigabit SFP is engineered to the highest quality standards and is 100% Cisco Meraki compatible, equivalent to the Cisco Meraki MA-SFP-1GB-SX SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Cisco Meraki or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers, and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports multimode fiber cable with a maximum distance of 550 m or 1804 ft., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM / DOM).
  • Reliable connectivity
    The Cisco Meraki MA-SFP-1GB-SX supports robust wired connectivity through its Ethernet 1000Base-SX cabling type, ensuring consistent performance for demanding networking tasks.
  • Enhanced diagnostic capabilities
    This module features Digital Diagnostics Monitoring (DDM) and Digital Optical Monitoring (DOM), providing critical insights into module performance and helping to maintain optimal operation.
  • Wide environmental range
    With an operational temperature range from 0°C to 70°C and humidity levels of 5% to 95%, this module is capable of performing reliably in diverse conditions.
  • Efficient data transmission
    The full duplex mode allows for simultaneous two-way data transmission, significantly improving overall network efficiency.
  • Compliance with industry standards
    The module meets several standards including IEEE 802.3z, UL, FCC, RoHS, and MSA, ensuring quality and compatibility within professional networking environments.
StarTech.com Cisco Meraki MA-SFP-1GB-SX Compatible SFP Module, 1000BASE-SX, 1GbE MMF Optic Transceiver, LC Connector, 550m, 850nm, DDM, Cisco Meraki MS225, MX400, Mini GBIC Transceiver - Lifetime Warranty (MASFP1GBSXST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
UL, FCC, RoHS, MSA
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
CRGJ StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.56
CRGJ StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £23.49
CRGJ StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.56
CRGJ StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £19.15
CRGJ StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.62
CRGJ StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
CRGJ StarTech.com Fiber Media Converter - Open In Stock £42.26
CRGJ StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Type: Modules
