StarTech.com Cisco Meraki MA-SFP-1GB-LX10
Quicklinx: D1VXWS00 Mfr#: MASFP1GBLX10
Type: Modules
Hurry, only 1 left in stock!
£40.23 ex VAT
£48.27 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over single-mode fiber with this SFP module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco Meraki switches and routers that support the Cisco Meraki MA-SFP-1GB-LX10 transceiver module, as well as other major brands of networking equipment.
This 1000Base-LX SFP delivers Gigabit connectivity over single-mode fiber cable, with a range of up to 10 km (6.2 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This single-mode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The SM Gigabit SFP is engineered to the highest quality standards and is 100% Cisco Meraki compatible, equivalent to the Cisco Meraki MA-SFP-1GB-LX10 SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Cisco Meraki or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers, and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports single-mode fiber cable with a maximum distance of 10 km or 6.2 mi., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM / DOM).
  • Reliable connectivity
    This SFP module provides stable wired connections, suitable for Gigabit Ethernet applications ensuring consistent network performance.
  • Digital monitoring capabilities
    Features such as Digital Optical Monitoring and Digital Diagnostics Monitoring allow users to keep track of the module's status and optimize performance.
  • Wide operating temperature range
    Designed to function in environments varying from 0°C to 70°C, this module is versatile and adaptable to multiple operational conditions.
  • Long-distance data transmission
    With a maximum transfer distance of 10 km, this module enables effective communication across greater distances within a network.
  • Compliant with key standards
    Meets various regulatory standards, ensuring safety, compatibility, and reliability in networking solutions.
StarTech.com Cisco Meraki MA-SFP-1GB-LX10 Compatible SFP Module, 1000BASE-LX, 1GbE SMF Optic Transceiver, 1GE Gigabit Ethernet LC Connector, 10km, 1310nm Cisco Meraki MS225, MX400, MS250 - Lifetime Warranty (MASFP1GBLX10) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Juniper SFP-1GE-LX
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-LX - LC single-mode female
UL, FCC, RoHS, MSA
Juniper SFP-1GE-LX
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
D1VX StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £20.78
D1VX StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £23.55
D1VX StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £16.71
D1VX StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £18.98
D1VX StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
D1VX StarTech.com Fiber Media Converter - Open In Stock £42.26
D1VX StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Type: Modules
