StarTech.com Cisco MA-SFP-10GB-LR SFP+
Quicklinx: CRGKWS00 Mfr#: MASFP10GBLR
Type: Modules
Hurry, only 1 left in stock!
£217.17 ex VAT
£260.60 inc VAT
Add reliable and cost-effective 10 Gigabit Ethernet connections over single-mode fiber with this SFP+ module. This StarTech.com 10 Gigabit fiber SFP+ is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco Meraki switches and routers that support the Cisco Meraki MA-SFP-10GB-LR transceiver module, as well as other major brands of networking equipment.
This 10GBase-LR SFP+ delivers 10 Gigabit connectivity over single-mode fiber cable with a range of up to 10 km (6.2 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit single-mode SFP+ is engineered to the highest quality standards and is 100% Cisco Meraki compatible, equivalent to the Cisco Meraki MA-SFP-10GB-LR SFP+ transceiver. The StarTech.com SFP+ transceiver module is configured and fully tested to ensure it works seamlessly with Cisco Meraki or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in Cisco Meraki switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SM fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 10Gbps.
  • Efficient connectivity technology
    The module utilizes wired connectivity technology to ensure stable and effective networking performance for various applications.
  • Robust environmental tolerance
    With a wide operating temperature range and humidity tolerance, this module is built to function reliably in diverse environmental conditions.
  • Versatile compatibility
    Designed to meet multiple compliance standards, including IEEE 802.3ae, UL, FCC, RoHS, and MSA, this module ensures broad compatibility with different networking systems.
StarTech.com Cisco Meraki MA-SFP-10GB-LR Compatible SFP+ Module, 10GBASE-LR, 10GbE SMF Optic Transceiver, Gigabit Ethernet SFP+, LC Connector, 10km 1310nm DDM, Cisco Meraki MS225, MX400 - Lifetime Warranty (MASFP10GBLR) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
1.39 cm x 5.84 cm x 1.26 cm
30 g
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ae
1 x Ethernet 10GBase-LR - LC single-mode female x 2
UL, FCC, RoHS, MSA
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
CRGK StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £304.01
Type: Modules
