StarTech.com Cisco GLC-TE Compatible SFP Copper Module - 1000BASE-T
Quicklinx: FLXRWS00 Mfr#: GLCTEST
Type: Modules
£44.74 ex VAT
£53.68 inc VAT
Express delivery Delivered on Wednesday
The GLCTEST is a Cisco GLC-TE compatible copper transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers for extended temperatures. It delivers dependable 1 GbE connectivity over copper cable, for 1000BASE-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable connectivity
    Equipped with a data transfer rate of 1 Gbps, this module ensures high-speed communication for demanding networking tasks.
  • Versatile compatibility
    Designed with an RJ-45 connector, this module is compatible with a variety of devices, allowing for flexible integration into existing networks.
  • Robust environmental resilience
    Operating effectively in a wide temperature range of -40°C to 85°C, the module is suitable for deployment in challenging environments.
  • Long-lasting performance
    The MTBF of 4,655,371 hours means this module is built to withstand extensive use, reducing the need for frequent replacements.
  • Easy installation
    The hot swap feature allows for simple module replacement without powering down the equipment, minimizing downtime during maintenance.
StarTech.com Cisco GLC-TE Compatible Module, 1000BASE-T Copper Industrial Gigabit Ethernet Transceiver, SFP to RJ45 Cat6/Cat5e 100m Extended Temp, Cisco Firepower, IE 2000, C9500, C2960 - Lifetime Warranty (GLCTEST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
Cisco GLC-TE
1.4 cm x 6.5 cm x 1.2 cm
72 g
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
100 m
Full duplex capability, hot swap module replacement
IEEE 802.3
1 x Ethernet 1000Base-T - RJ-45
MTBF
4,655,371 hours
FCC, RoHS, WEEE, REACH, MSA
Cisco GLC-TE
1.4 cm
6.5 cm
1.2 cm
72 g
Limited warranty - lifetime
-40 °C
85 °C
30 - 75%
FLXR StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.13
FLXR StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
FLXR StarTech.com Fiber Media Converter - Open In Stock £42.26
FLXR StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Type: Modules
