StarTech.com Cisco FET-10G Compatible SFP+ MM Module - 10GBase-USR
Quicklinx: FHJ0WS00 Mfr#: FET-10G-ST
Type: Modules
£125.31 ex VAT
£150.37 inc VAT
The FET-10G-ST is a Cisco FET-10G compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10Base-USR compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable performance
    With a mean time between failures (MTBF) of 498,745,585 hours, this SFP+ module is designed to deliver consistent and dependable performance in demanding networking environments.
  • High-speed data transfer
    Capable of transferring data at rates of 10 Gbps, this module facilitates rapid data communication, which is essential for bandwidth-intensive applications.
  • Enhanced monitoring capabilities
    Equipped with Digital Diagnostics Monitoring (DDM), this module allows users to monitor its operational status, enhancing network management and troubleshooting.
  • Seamless connectivity
    Featuring LC multi-mode connectors, this SFP+ module supports easy integration into existing systems, ensuring efficient connectivity and reliable data transfer.
  • Long-distance transmission
    This module supports a maximum transfer distance of 100 m, making it suitable for various networking scenarios while maintaining high data integrity.
StarTech.com Cisco FET-10G Compatible SFP+ Module, 10GBASE-USR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 300m, 850nm, DDM, Cisco Nexus 2000 - Lifetime Warranty (FET-10G-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-USR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
100 m
Cisco FET-10G
5.84 cm x 1.39 cm x 1.37 cm
20 g
Cisco Nexus 2224TP, 2232PP 10GE, 2232TM, 2248TP, 2248TP-E, 93180YC-FX, 9336C-FX2, 9372PX-E
Plug-in module
Wired
Cabling Type
10GBase-USR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
100 m
Full duplex mode, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ae
1 x Ethernet 10GBase-USR - LC multi-mode female x 2
MTBF
498,745,585 hours
MSA
Cisco FET-10G
5.84 cm
1.39 cm
1.37 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Cisco Nexus 2224TP Fabric Extender, 2232PP 10GE Fabric Extender, 2232TM Fabric Extender, 2248TP Fabric Extender, 2248TP GE Fabric Extender, 2248TP GE Fabric Extender for N5K/N2K Bundle, 2248TP-E Fabric Extender, 2248TP-E GE Fabric Extender, 2248TP-E GE Fabric Extender Reversed Airflow Pack, 2248TP-E GE Fabric Extender Standard Airflow Pack, 93180YC-FX, 9336C-FX2, 9372PX-E
Type: Modules
