StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F
Quicklinx: 6PF8WS00 Mfr#: ROLLOVER
More than 50 In Stock
£5.41 ex VAT
£6.49 inc VAT
This durable Cisco Console Rollover Adapter is a compact solution for converting Ethernet cable into a Rollover cable (Cisco Console Cable). The adapter conforms to the Yost Serial Device Wiring Standard.
  • Reliable connectivity
    The Cisco Console Rollover Adapter ensures consistent connections between devices, facilitating efficient data transmission for networking tasks.
  • Durable construction
    With a robust PVC jacket, this adapter cable withstands regular use while protecting the internal wiring from damage.
  • Easy to use
    Designed with straightforward connectors, the adapter allows for quick connections between RJ-45 devices, simplifying your networking setup.
StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable - Network adapter cable - RJ-45 (M) to RJ-45 (F) - blue - ROLLOVER - network adapter cable - blue
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - female
Blue
Network Cable Type
Jacket Material
PVC
Blue
Connector
RJ-45 - male
RJ-45 - female
RoHS
6PF8 StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F In Stock £22.00
6PF8 StarTech.com Gigabit Cat 6 Crossover Ethernet Adapter In Stock £6.61
6PF8 StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F In Stock £5.41
6PF8 StarTech.com Serial Null Modem Adapter In Stock £5.24
6PF8 StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £5.24
6PF8 StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M In Stock £6.80
