This durable Cisco Console Rollover Adapter is a compact solution for converting Ethernet cable into a Rollover cable (Cisco Console Cable). The adapter conforms to the Yost Serial Device Wiring Standard.
Reliable connectivity
The Cisco Console Rollover Adapter ensures consistent connections between devices, facilitating efficient data transmission for networking tasks. -
Durable construction
With a robust PVC jacket, this adapter cable withstands regular use while protecting the internal wiring from damage. -
Easy to use
Designed with straightforward connectors, the adapter allows for quick connections between RJ-45 devices, simplifying your networking setup.
- StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable - Network adapter cable - RJ-45 (M) to RJ-45 (F) - blue - ROLLOVER - network adapter cable - blue
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - female
- Blue
- Limited lifetime warranty
- Network Cable Type
- Jacket Material
- PVC
- Blue
- Connector
- RJ-45 - male
- RJ-45 - female
- RoHS
StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F | In Stock | £21.71 |
StarTech.com Gigabit Cat 6 Crossover Ethernet Adapter | In Stock | £6.63 |
StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F | In Stock | £5.58 |
StarTech.com Serial Null Modem Adapter | In Stock | £5.51 |
StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M | In Stock | £7.27 |
