The SFP10GBTCST is a Cisco compatible copper transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBASE-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This SFP+ copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com SFPs
All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
 - StarTech.com Cisco SFP-10GB-TC Compatible SFP+ Module, 10GBASE-T, SFP to RJ45 Cat6/Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, Cisco Firepower, ASR1000, ASR9000, 10Gbps SFP+ - Lifetime Warranty (SFP10GBTCST) - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - RJ-45
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-T
- Data Transfer Rate
 - 10 Gbps
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 30 m
 - 1.34 cm x 6.98 cm x 1.38 cm
 - 24.2 g
 - Limited lifetime warranty
- Form Factor
 - Plug-in module
 - Silver
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-T
 - 10GbE
 - 10 Gbps
 - 30 m
 - Auto-uplink (auto MDI/MDI-X), full duplex mode
 - IEEE 802.3an
 - 1 x Ethernet 10GBase-T - RJ-45 female
- MTBF
 - 4,598,430 hours
 - FCC, RoHS, MSA
 - 2.3 Watt
 - 1.34 cm
 - 6.98 cm
 - 1.38 cm
 - 24.2 g
 - Limited warranty - lifetime
 - 0 °C
 - 70 °C
 - 95%
