StarTech.com Cisco Compliant 10GBase-T SFP+ Transceiver Module
Quicklinx: DZ7CWS00 Mfr#: SFP10GBTCST
Type: Transceiver
Hurry, only 1 left in stock!
£149.88 ex VAT
£179.85 inc VAT
The SFP10GBTCST is a Cisco compatible copper transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBASE-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This SFP+ copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
  • StarTech.com SFPs
    All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Cisco SFP-10GB-TC Compatible SFP+ Module, 10GBASE-T, SFP to RJ45 Cat6/Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, Cisco Firepower, ASR1000, ASR9000, 10Gbps SFP+ - Lifetime Warranty (SFP10GBTCST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - RJ-45
Plug-in module
Cabling Type
10GBase-T
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
30 m
1.34 cm x 6.98 cm x 1.38 cm
24.2 g
Plug-in module
Silver
Wired
Cabling Type
10GBase-T
10GbE
Data Transfer Rate
10 Gbps
30 m
Auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3an
1 x Ethernet 10GBase-T - RJ-45 female
MTBF
4,598,430 hours
FCC, RoHS, MSA
2.3 Watt
1.34 cm
6.98 cm
1.38 cm
24.2 g
Limited warranty - lifetime
70 °C
95%
Type: Transceiver
