StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC)
Quicklinx: 82HRWS00 Mfr#: SFPG1320C
Type: Modules
More than 50 in stock
£41.04 ex VAT
£49.24 inc VAT
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPG1320C Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC - 20 km (12.4 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Single-Mode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1310nm single-mode SFP module is compatible with Cisco equipment.
StarTech.com Cisco GLC-LH-SMD Compatible SFP Module - 1000BASE-LH - 1GE Gigabit Ethernet SFP 1GbE Single Mode Fiber SMF Optic Transceiver - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LH
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
20 km
0.9 cm x 6.5 cm x 1.4 cm
25 g
P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, IES101G2SFPW, IES101GP2SFW, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-LH
GigE
Optical Wave Length
1310 nm
20 km
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-LH - LC single-mode
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, MSA
0.9 cm
6.5 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
82HR StarTech.com Gb MM SFP Fiber Transceiver In Stock £39.85
82HR StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £15.91
82HR StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £40.00
82HR StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £41.04
Type: Modules
Price Range Ex VAT: 0 - 50
