Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPG1320C Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC - 20 km (12.4 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Single-Mode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1310nm single-mode SFP module is compatible with Cisco equipment.
Reliable connectivity
This SFP transceiver module ensures stable data transfer at speeds of 1 GbE over single-mode fiber, ideal for high-demand networking environments. -
Versatile compatibility
Designed to comply with standards like FCC, RoHS, and MSA, this module integrates into various network setups. -
Robust temperature tolerance
Functional between 0 °C and 70 °C, this module is capable of operating in diverse environments without compromising performance. -
Enhanced monitoring capability
Equipped with a Digital Diagnostics Monitoring Interface (DDMI), this transceiver allows for management and troubleshooting. -
Efficient data transmission
With optical wave length of 1310 nm, the module supports communication for Gigabit Ethernet applications.
- StarTech.com Cisco GLC-LH-SMD Compatible SFP Module 1000BASE-LH 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver 1GE Gigabit Ethernet SFP LC 20km, 1310nm, DDM, Cisco Firepower, IE2000 - Lifetime Warranty (SFPG1320C) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LH
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 20 km
- 0.9 cm x 6.5 cm x 1.4 cm
- 25 g
- Limited lifetime warranty
- Designed For
- P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, IES101G2SFPW, IES101GP2SFW, MCM1110SFP, PEX1000SFP2
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LH
- 1GbE
- 1310 nm
- 20 km
- Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- IEEE 802.3z
- 1 x Ethernet 1000Base-LH - LC single-mode
- Compatible Slots
- 1 x SFP (mini-GBIC)
- FCC, RoHS, MSA
- 0.9 cm
- 6.5 cm
- 1.4 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- Designed For
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £35.36 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £16.00 |
StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) | In Stock | £36.73 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £40.45 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £24.09 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £24.09 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £35.41 |
StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £21.31 |
StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £24.13 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £17.13 |
StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £19.44 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £142.63 |
StarTech.com Fiber Media Converter - Open | In Stock | £43.33 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £328.89 |
