StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC)
Quicklinx: 8M4GWS00 Mfr#: SFPGLCLHSMST
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGLCLHSMST Cisco Compatible Gigabit Fiber SFP Transceiver Module SM/MM LC is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade an SFP slot on your Gigabit fiber networking equipment or fiber media converter.
Supporting a 1000Base-LX/LH network with data rates up to 1.25 Gbps, this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. The SFP transceiver supports both single-mode and multi-mode LC ports, with a single-mode distance of 10 km (6.2 mi.) and multi-mode distance of 1.5 km (.9 mi.). Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1300nm single-mode/multi-mode SFP module is compatible with the Cisco GLC-LH-SM transceiver. Also a perfect accessory for the StarTech.com PEX1000SFP PCI Express Open SFP NIC (PEX1000SFP), or ET1110PSE Gigabit POE Open SFP Media Converter (ET1110PSE) products.
  • Reliable connectivity
    This SFP module ensures consistent connections for networking, ideal for communication across different network infrastructures.
  • Efficient performance
    With a data transfer rate of 1.25 Gbps, this module supports fast data exchange, suitable for high-demand applications.
  • Extended range
    A maximum transfer distance of 10 km allows for effective connections over long distances, enhancing network flexibility.
  • Versatile compatibility
    The LC single-mode connector and compliance with multiple standards enable compatibility across various networking equipment.
  • Advanced monitoring
    Digital Diagnostics Monitoring Interface (DDMI) provides critical details for monitoring system performance and facilitates maintenance.
StarTech.com Cisco GLC-LH-SM Compatible SFP Module, 1000BASE-LX/LH, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, Cisco IE3400, IE3300, IE3200, Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFPGLCLHSMST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LH
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
1.2 cm x 6 cm x 1 cm
17 g
P/N: ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-LH
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-LH - LC single-mode
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, MSA
1.2 cm
6 cm
1 cm
17 g
Limited warranty - lifetime
70 °C
8M4G StarTech.com Gb MM SFP Fiber Transceiver In Stock £35.36
8M4G StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
8M4G StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
8M4G StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.49
8M4G StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.84
8M4G StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £16.00
8M4G StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £21.31
8M4G StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.13
8M4G StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.13
8M4G StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.44
8M4G StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £142.63
8M4G StarTech.com Fiber Media Converter - Open In Stock £43.33
8M4G StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £228.89
8M4G StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.48
8M4G StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £37.59
8M4G StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £328.89
